I need to replace power entry module, does anyone have a part #
Mon Apr 03 2023
Tue Apr 04 2023Reply from T-Lobato
Hill452,
Check out this link. There is a power supply on there, not sure if it's the part number you're looking for.
T.
https://www.partssource.com/catalog/integra-lifesciences-holding-corporation/mlx
TJ Lobato | MedWrench Guru
Tue Apr 04 2023Reply from Hill452
I did not pop it out, so all I see is corcom on the outside. It is at a remote site so will have to run back to pop out and see if it has a part # from manufacture.
Thanks, Brian
Ok. What I found confusing was the name on the device is Luxtec, but found parts under the holding corporation which is Integra Lifesciences. You may try searching for parts under that name.
