Hello I have a device that has a problem with cutting shorts happen in the circuit and the fuse burns I tried to look for the maintenance manual and I couldn't get it I hope for help
Thu Apr 06 2023
shorts bn 732052
Mon Apr 10 2023Reply from Chris-CBET
Have you checked tension on your ports. I've seen loose connections causing arcing, and that will blow fuses.
