Tue Apr 11 2023
Remove CCA Program?
We have purchased some refurbished Hospira Plum A+ pumps and they have the prior hospitals CCA selection programing on them.  Is there a way to get rid of this and not use the drug info, etc.?  We are a veterinary hospital and do all our calculations manually.
   RE: Infusion Pump Report Post
Tue Apr 11 2023Reply from drakon
Hi Jennifer,
I don't think that there is a way to remove the CCA selection from a Mednet pump. I believe you would need to create a drug library with just 1 CCA and push it out via Mednet. It might just automatically default to it upon start up and you won't need to select it? Curious to know if it would do that or not.
Wed Feb 04 2026Reply from Nicky M
Hi Jennifer,
We are in the exact same situation and wondered if you ever figured out how to remove the prior CCA Selection programming. Based on this forum and the user manual we would need access to Mednet, which appears to be exclusive to human medicine. If we're unable to change the previous programming, will it cause any issues when using the pumps for our patients? Thanks in advance for any help you can provide!
