Wed Feb 02 2011
Elite 6001 surgery table floor brake issue
Skytron Elite 6001 surgery table problem I have an older 6001 with brake retraction issues: they will deploy fine, but will not retract. It is a dual port solenoid (same as each of the others except lift) and I have changed the check valves, removed and checked the needle valves. The only time it seemed to retract the floor brakes correctly is when there was a leaky 'o' ring on one of the check valve cover screws. This doesn't have a manual release; If I open the checkvalve cover port screw, fluid escapes under moderate pressure and the brakes begin to retract under the weight of the table. Help anyone???
Thu Mar 24 2011Reply from Fixit
Fixit
Skytron made several brake versions. Three pistons with a spreader bar on the front (earlier models) four pistons (later versions) the fact that you have a dbl operating solenoid should be the latter. (There should be two hydraulic lines on each piston) Question: Do all the pistons not retract or just one / two? That would indicate a faulty piston. Assuming they all don't retract: Check that the down side of the solenoid actually energizes when you press the release button on the hand control. It is indicated by the plastic on the end of the solenoid changes color. If not replace that side of the solenoid. If that's ok and your check valves on both sides of the solenoids are good.(there should be four but may only have two depending on vintage) then remove the shuttle valve and look for corrosion which can be cleaned with very fine emery paper. Replace all and test. All that being said, I made the assumption that you checked the hand control to verify that the button is actually working. If you have another table swap the hand control and see if the problem resolves. Hope it helps.
Jeffrey Hair
Regional Director
[b]STS North America[/b]
[i]Offering a high quality, cost effective alternative to manufacturers service for sterilization and related products in Healthcare, Scientific, and Industrial facilities[/i]888-607-7779
[url]http://www.stsnorthamerica.com[/url]
