Sun Feb 06 2011
diluent overflows in the bath
What may be the cause of diluent overflowing?I use the self test and all are normal, except that the bath is not draining properly and it overflows when doing some maintenance.Thank you
   RE: Hematology Analyzer Report Post
Mon Feb 07 2011Reply from GaryBiomed
GaryBiomed
Here is the world wide contact list for mindray. This may help [url=http://www.mindray.com/en/aboutus/global.html]World wide contacts...[/url]
Tue Oct 20 2015Reply from Joseph Kofi Odu
Replace valve 10(the valve just below the count bath.) This is Joseph Odu from Ghana.
Wed Feb 17 2016Reply from luis.lopezd
the problem is a clog on valves of waste don´t rembember the number but in the chamber with overflow, follow the tubes until you will see the valves
