Fri May 05 2023
mini rotary evaporator
Leakage problems: Check that the various parts of the equipment are properly installed and sealed. If you need to replace the seals or pipes, you can contact the equipment supplier or maintenance personnel for replacement. Insufficient vacuum: Check that the vacuum pump is working properly, and clean the filter and pipes to ensure smooth flow. If parts need to be replaced, please contact the equipment supplier or maintenance personnel for replacement. Temperature control issues: Check that the unit's temperature controller is set correctly and make sure the temperature sensor is not faulty. If you need to replace the temperature controller or sensor, you can contact the equipment supplier or maintenance personnel for replacement. Spin speed issue: Check that the mini rotary evaporator is spinning at the correct speed to ensure adequate evaporation and separation. If the motor or controller needs to be replaced, please contact the equipment supplier or maintenance personnel for replacement. Condenser Problems: Check that the condenser is working properly, and clean the internal pipes to ensure they are clear. If you need to replace the condenser or coolant, you can contact the equipment supplier or maintenance personnel for replacement. Control panel issues: If you're having problems with your device's control panel, you can try restarting your device or resetting the control panel. If the problem still exists, you can contact the equipment supplier or maintenance personnel to repair or replace the control panel.
Equipment: mini rotary evaporator
