Just bought refurbished. Probes work on other machine but when I connect to this machine, it keeps telling me there’s an error connecting probe 106 to the port. Any suggestions?
Ge voluson s8
RAB6- RS is supported by Voluson S8 from BT14 and higher versions.
IC9-RS is supported by Voluson S8 from BT16 and higher versions.
Make sure, that you have compatible version of the system.
How to check system version: UTILITIES > SYSTEM SETUP > ADMINISTRATION > SYSTEM INFO tab. And check the Application Software version.
If everything is ok and system version is compatible, then you should check system log and run system diagnostics to define the problem. If you have some questions or need support - email me: governor.deadline@gmail.com
It wont let me do anything without a probe connected. Cant get to utilities:( is this normal?
