Hi. I have a Savina 300. This ventilator it's with a code error 50.000. Someone knows what can be that?
Mon May 08 2023
Error code 50.000
Mon May 08 2023Reply from MapleTreeBiomed
Hi Idiogosantos,
I believe 50.000 means the system can't detect that the speaker is plugged in. The documentation I found states "1. Check loudspeaker connection to Frontpanel PCB. 2. Replace loudspeaker." So I'd start there.
Good Luck!
