The CMOS battery retains the optional vent modes. Once you remove the battery it will loose those options. You can not reuse the same option codes. You have to contact Drager support with the machines serial number and request new codes to be installed. They will look up the machines serial number to verify which vent modes it should have. I've done this before and it doesn't take long. Just be in front of the machine before calling. They'll help you enter the new codes.
FYI: If your careful, you can replace the CMOS battery while the machine has been powered on. When it's powered on, it will retain the installed codes while you change the battery. Only perform this if you feel comfortable with it and keep in mind that the machine and its internal components are powered on.
