Fri Jun 09 2023
Sram 9600
How do I load the data back onto the SRAM card?
The battery wore out.
I have the 3 & 1/2 floppy and SRAM card (w/new battery).
Anyone know?
Sat Jun 10 2023Reply from Chaovalit
I too ran into the same problem. Waiting for an answer from someone who knows.
Sat Jun 10 2023Reply from C12Guy
C12Guy
If you can get the system to boot and taking X-ray with the system powered on take out the sram. Replace the battery then put the sram back in the system. The system will write back to the sram.
C12Guy, Thanks for your kindly support.
Sun Jul 23 2023Reply from Traveling FSE
If the system won’t boot (SRAM error) you’ll likely need to order a replacement unless you have all of the setup to write to a sram card.
You’d need a specific writer to convert to card.
I ended up calling a company Chesapeake Medical Systems and they sent replacement out
