Hello, I have a problem with a bed, the knee down, head down, foot down functions do not lower their respective functions. The bed only performs the elevation functions but does not do any lowering
Tue Jun 20 2023
Hill Rom P1900 Hydraulic Manifold Failure
Tue Jun 20 2023Reply from Chris-CBET
Wed Jun 21 2023Reply from Emily Vitkovitsky
Fri Jun 23 2023Reply from marianomedina_6724
Hi Chris, so far I have checked the voltages of the solenoid valves and the motor, in that everything is fine, I thoroughly cleaned the hydraulic manifold and replaced the hydraulic oil, verified that the cables that reach the solenoid valves are correct, however the bed continues to fail and does not do the positions well
Fri Jun 23 2023Reply from Chris-CBET
I'm wondering if you have a stuck button situation which is common on these beds. disconnecting the siderails will tell you if that is your issue or not
