Fri Jun 23 2023
error code 244
what can I do with error code 244
Equipment: ACIST - EmpowerCTA
   RE: Contrast Media-Injector System Report Post
Fri Jun 23 2023Reply from cgentry
error code 244 injector not working
Tue Jun 27 2023Reply from Ryan C.
Issue points to an issue with the start pendant.  Ensure the button is not stuck latched.  Remove the pendant to see if the error clears.  Clean the connector and the connector port.  If error persists after cleaning and/or removal of the switch, then issue points to a suspect controller CPU board.
Ryan Clarke - ISS  |  We Are ISS  |  888-667-1062
