Fri Jun 23 2023
PSP and tray - how are they connected?
PSP and tray - how are they connected?  Is the PSP bonded to the tray? If the PSP separates from the tray can it be re-attached using double sided tape or some other adhesive?
Fri Jun 23 2023Reply from XrayGuy3
THIS IS FOR AN AGFA CR 30X
Sun Jul 09 2023Reply from deesmithk
Are you referring to the cr30 version 1 or 2? I have worked on the version 1 a bit and do not know of any psp.
Sat Jul 29 2023Reply from deesmithk
If you are not sure of the version of the cr30 that you have, then look for the main power switch. If it in the rear the version is "1". If it is in the front under the input tray, then it is version "2". I do not have much knowledge of version 2, as most of the units in this area have been version 1.
