Hello! The ventilator don't turn on. Our service center says that faulty kit plate connector carrier board assembly item NM1805003-s. How we may repair this board?
Tue Jul 25 2023
Don't turn on
Wed Aug 02 2023Reply from T-Lobato
I highly doubt you'll be able to repair the board without schematics. Even then, if the board has micro-components, I would say it's not doable. If you have another machine, you could replace the board from that unit to see if that solves the power on issue. Then, you may be able to buy the board alone from a third party vendor.
TJ Lobato | MedWrench Guru
