Sun Aug 06 2023
Draeger - Permox Silent Care - Tech Help Please
I have a Draeger Permox Silent Care with the following symptoms:-
- If switched on with airflow restricted (4Lpm for example), then it triggers an immediate alarm mode and shuts down the compressor.
- If switched on with airflow unrestricted (regulator fully opened) it runs just fine and produces oxygen.  If left to run, after 5 minutes you get a 3-beep alarm, but it continues to run.
- One it is running unrestricted,  if the airflow is restricted (to 4Lpm for example), then after a while it will go into a single continuous alarm and shut down the compressor.
- I have checked all the pipes, no kinks or snags found, and with the regulator fully open it easily exceeds the flow measurable by the flow meter.
- Filters are all clear.
- Compressor runs nicely
Can anybody please advise on what may be wrong?
I notice there is an RS232 port and also a header pin block on the PCB.  Can I use these to aid diagnostics?
Is there ANY technical or service documentation available apart from the standard use manual?
I am located in Hampshire U.K..  Are there any service places nearby?
Many thanks for any help or advice.
   RE: Oxygen Concentrator Report Post
Mon Aug 07 2023Reply from Emily Vitkovitsky
Emily Vitkovitsky
Agiliti
Mon Aug 07 2023Reply from Steve Reedy
Hi,
I am unable to locate an Agiliti office in England or the UK. Are they USA only? or am I just failing to find them?
Thanks
Steve
