how replace back up battery
Equipment: Lumenis Opus 10
Hi Grim,
This laser is long out of support and I can't seem to find a manual online. I would only recommend replacing the battery if you are comfortable working on electronics. The battery is likely a 3V lithium or coin style battery on the control board. Again, I wouldn't open the case up unless you know what you are doing.
Good Luck!
