Mon Sep 04 2023
stern weber -sw-17
hello the stern weber sw 17 autoclave gives me error h405 what should i do fix error?thank you
Tue Sep 05 2023Reply from MapleTreeBiomed
MapleTreeBiomed
Hi Reza123,
The manual located int he documents sections states that error h405 is excessive steam pressure past the max limit. Then states; Problem in the hydraulic circuit. or
Steam generator malfunction. In both instances contact the manufacturer.
Start there and hopefully they can assist you.
Good Luck!
