Wed Oct 04 2023
Battery Source
Does anyone have a battery source for these devices?  Baxter (formerly Hill-Rom, formerly Welch Allyn) requires them to be sent in for about $400 a piece with a 4 week turnaround.
   RE: Vision Screener Report Post
Tue Jan 02 2024Reply from mah3r
How'd you get the cover off?
Wed Jan 10 2024Reply from Chris S
Chris S
There are 2 screws in the back.  Remove and pop the back cover off.  Remove the front label to expose 4 screws.  Remove those screws and you can pop off the front, and then you will be able to see and access the battery.
Wed Jan 10 2024Reply from mah3r
That's going to permanent damage the front cover, I guess I'll have to call the company to see if they sell the other overlay
Sat Oct 26 2024Reply from Brian S
There are only 2 screws visible on the bottom of the unit.  I'm not feeling any indentations under any of the labels that are consistent with 4 hidden screws.  There *may* be one under the wifi label on the bottom, but certainly not 4.
Wed Nov 12 2025Reply from mi
did someone manage to replace battery? there is no obvoius way to open chassis, and there is some rish of damaging device, so maybe any hints?
