Does anyone know how to correct a error code 0xC100?
Equipment: Hillrom - Centrella Smart + Bed
The manual doesn't show an error code: 0xC100. it shows
0x10C0 CPR switch failure (1) Check the cable connections between the
CPR switch and the MCB. Replace or connect
the cable as necessary.
(2) Replace the CPR switch.
It’s seems to be an issue with the MCM system. It won’t let me access the settings to turn it fully off, it seems to be that if the MCM system isn't active for more than 24hrs the alarm will go every hour. :,(
Not yet but that will be my next step, thank you for replying and helping I appreciate you very much
