Wed Feb 21 2024
Voluson 730 does not turn on
Hello friends, Our device does no turn on. Stays on "CHECK SIGNAL" screen. Where might the problem be?
Wed Feb 21 2024Reply from Emily Vitkovitsky
Emily Vitkovitsky
MERCO Biomedical
Encore Technical Services
Sun Feb 25 2024Reply from minipilot
Probably the PC motherboard is faulty.
Sun Feb 25 2024Reply from FrepaAL
FrepaAL
Hello!
First of all, you have to check the BIOS battery, if it is less than 1V, replace the battery and start up the system, enter to BIOS SETUP and set correct hour and date, after that system will boot up normally. If this is not the case, check RAM and than CPU processor. In very seldom cases PC main board faulty can be also.
Thu Feb 29 2024Reply from makehand
Dear Emily, minipiot, FrepaAL, thank you so much)
