Wed May 15 2024
Accessing and storing ecg records
I want to know if the machine stores the records of ecg autonatically and how can i sent them over to my pc so that i can analyze the signal
Equipment: Mortara - ELI 250
Wed May 15 2024Reply from TSS Jim
Which unit do you have. The ELI250 or the ELI250c. The 250c has a blue screen and yellow tracing. If you have the older ELI250, it is obsolete. If you have the ELI250c, the unit does store records and they can be transmitted to a program called ELI Link which can create a PDF or XML file. Contact Baxter who now owns the ELI250c line and the tech support team can help you determine if the unit you have can transmit. HRC_mor_Tech.Support@baxter.com
