Tue Aug 20 2024
Date goes back to 2012-CMOS battery location
I checked in the manual an don't see a procedure for location of the CMOS and proper way to set date time after battery replacement.  Someone want to share?
Tue Aug 27 2024Reply from The Ziehm Guy
Good Evening Matt,
There are several versions of the video processing board (the main board inside the system), but they all use the 2032 battery that hold time and date. You may need to remove the cord reel to see the battery, but it's there. There is no written procedure. Call me if you need me.
Thu Sep 12 2024Reply from Minicarm.com
Minicarm.com
On the Orthoscan FD Pulse mini C-Arm there are some video boards that you can change the CMOS battery and some boards that you cant.
Joshua Bacon
Vice President
PH: 1 (800) 643-2998
www.minicarm.com
