Fri Aug 30 2024
Error 6 on mobillet 2
How to resolve Error 6 please help me how do I resolve this error
Mon Sep 02 2024Reply from Jlinton
Jlinton
An Error 6 on the Mobillet 2 X-ray unit generally pertains to a communication error or an electrical fault
Steps to Resolve Error 6 on Mobillet 2:
  1. Power Cycle the Unit:
    • Start by performing a power cycle:
      • Turn off the unit and disconnect it from the power source.
      • Wait for about 2-5 minutes to allow the system to fully discharge.
      • Reconnect the power and turn the unit back on.
    • This can sometimes clear minor communication errors or faults.
  2. Check for Loose Connections:
    • Inspect all cables and connections within the unit, especially those related to the X-ray tube, detector, and control panel.
    • Ensure that all connectors are properly seated and free of dust or debris that could cause a poor connection.
  3. Inspect the Power Supply:
    • Verify that the power supply to the unit is stable and within the required voltage range. Fluctuations or poor grounding can trigger errors.
    • If using a battery-powered unit, ensure the battery is properly charged and in good condition.
  4. Contact Technical Support:
    • If the steps above do not resolve the error, contact Technical Support
