Hi. I bought a used Micrel - Micropump MP Daily + that has its upper rate setting 60mm and lower rate setting 40mm. how can I get the lower rate setting down to 5mm
Equipment: Micrel - Micropump MP Daily +
Hi Kwame61,
You can find the user manual HERE. Page 23 in the Configuration section mentions setting the upper and lower rate limits at the top of page 24. So follow the instructions on page 23 to put the pump into configuration mode. Then find the values you need to adjust.
Good Luck!
