Can anyone tell me how to delete studies from an Innova when the DB is full?
Tue Sep 17 2024
GE INNOVA
Wed Sep 18 2024Reply from Jlinton
To delete studies from a GE Innova system when the database is full, follow these general steps. Be sure to proceed carefully, as deleting studies permanently removes them from the system.
Steps to Delete Studies from GE Innova:
Log In as Administrator:
- You will need administrator access to delete studies. Log in using the administrator credentials.
Access the Database Management Tool:
- Depending on your GE Innova model, you can access the database or archive management tools through the system menu.
- Navigate to the study management or archiving section, where you can manage the stored studies.
Filter or Search for Studies:
- Use filters to search for studies based on criteria like date, patient ID, or study type. It’s important to carefully choose the studies you wish to delete.
Select Studies to Delete:
- Highlight the studies you want to remove. Be sure you are selecting the correct studies, as deletion is usually irreversible.
Archive or Backup Studies (Optional):
- Before deleting, it’s good practice to archive or back up studies to an external drive, PACS, or long-term storage. This ensures important data is not lost.
- Use the archiving option from the system menu if this step is needed.
Delete Studies:
- Once you've selected the studies to delete, confirm the deletion. The system may ask for confirmation to prevent accidental loss of data.
