How to solve err 148/35 with the problem of the collimator not opening or the image not appearing on the monitor screen?
Equipment: SIEMENS - LUMINOS TL
Error 148/35 on the Siemens Luminos TL is typically related to an issue with the collimator system, potentially affecting the functionality of the image intensifier or monitor display. Here's a troubleshooting guide to resolve this problem:
Power Cycle the System:
Check Collimator Connections:
Verify Collimator Motor Functionality:
Inspect Power Supply to Collimator:
Software or Firmware Error:
Monitor and Video System Check:
Diagnostic Mode or Logs:
High James,
Thanks for the detailed info regarding error 148/35 on SIEMENS Luminos TL.
Perhaps you can share your expertise on how to adjust/set the potentiometer for Luminos Classic RF 55 table's longitudinal movement.
Best Regards,
Kim Sr Luy
