Thu Oct 03 2024
Unit powers on then off immediately after, nothing from monitors and power supply has a flashing blue light
As the subject says the unit powers on then off immediately after, nothing from monitors and power supply has a flashing blue light, the cause for this is unknown and I am getting no warning lights from the power distribution board.
Equipment: Phillips iU22
Thu Oct 03 2024Reply from mozzy ug
the dc power is having some issues
Thu Oct 03 2024Reply from Jlinton
Jlinton
When your Philips iU22 ultrasound system powers on and then shuts off immediately, accompanied by a flashing blue light on the power supply and no warnings from the power distribution board, it can be indicative of several potential issues. Here’s a structured approach to troubleshoot the problem:
Troubleshooting Steps:
  1. Check Power Supply Connections:
    • Ensure that all power supply connections are secure and properly seated. Loose or damaged connections can cause the system to fail during the power-on sequence.
  2. Inspect the Power Cable:
    • Examine the power cable for any visible signs of wear, fraying, or damage. A faulty power cable can prevent proper power delivery to the system.
  3. Evaluate the Power Supply Unit (PSU):
    • The flashing blue light usually indicates an issue with the power supply. If possible, test the power supply unit with a multimeter to ensure it's outputting the correct voltage. If it's not functioning properly, it may need to be replaced.
  4. Check for Overheating:
    • If the system has been running for an extended period prior to this issue, check for signs of overheating. Allow the unit to cool down and try powering it on again.
  5. Examine the Internal Components:
    • If you’re comfortable and have the technical expertise, open the unit and inspect the internal components for any signs of damage, burnt components, or loose connections. Look particularly at the main board and power distribution board.
  6. Look for Error Codes or Logs:
    • If the unit has an internal diagnostic system, check for any logged errors or messages that might indicate the problem. This may require accessing the system’s service menu.
  7. Perform a Hard Reset:
    • Unplug the unit from the power source and leave it disconnected for several minutes. This can sometimes reset the internal circuitry.
  8. Inspect the Monitors:
    • Ensure that the monitors are properly connected and functioning. A faulty monitor connection can prevent the system from fully initializing.
  9. Check for Faulty Hardware:
    • Components such as the main control board, power distribution board, or other internal parts might be malfunctioning. If you suspect this, it might require professional diagnosis and repair.
