Tue Oct 15 2024
Record/Print Speed
I have noticed the mm/s is not adjustable nor does the general setup save the cm/min on restart. What I found out so far is the cm/min can be set from 1 to 3 cm/min. The "paper advance" button is set at 40 cm/min. My goal is to change the default settings to either 50 mm/s or 3 cm/min without having to change the general setup on restart. Trying to find a solution for this goal/problem.
   RE: System Report Post
Tue Oct 15 2024Reply from Bill L.
Try setting it and then go into Install Options 2 screen and select Store Current to Hospital (assuming the Default Settings is Hospital). That should save the setting.
