Need Humidity Limites for the Century V-120, JACHO says we must know this so we don't oper: said same in the wrong inverioment,,,,,,,,???? should be somewhere in the enviromental operational peramitures...
Humidity
Hi Scottde,
All I could find was a MANUAL ON THEIR SITE that says it's 10-90%. The manual is for the "Century" but doesn't specifically call it a Century V120. Though maybe the V120 is just for the voltage configuration?
Good Luck!
v120 and v116 refer to the dimensions of the chamber(v120 = 20 x 20 x 38?, v116 = 16 x 16 x 26? )
and..
from the ops manual
2.2.3 Utility Requirements
Hinged Door — 44 x 511 /2 x 751 /4" (1118 x 1308 x 1911 mm) Sliding Door — 70 x 57 x 751 /4" (1778 x 1448 x 1911 mm) Hinged Door — 44 x 631 /2 x 751 /4" (1118 x 1600 x 1911 mm) Sliding Door — 70 x 69 x 751 /4" (1778 x 1753 x 1911 mm) Hinged Door — 44" x 751 /2" x 751 /4" (1118 x 1918 x 1911 mm) Sliding Door — 70 x 81 x 751 /4" (1778 x 2057 x 1911 mm) 3800 lbs (1720 kg) 4200 lbs (1901 kg) 4700 lbs (2127 kg)
Controls 120 V, 2 A, 1-phase Vacuum Pump 208/240 V, 6 A, 3-phase, or 480 V, 3 A, 3-phase
• Water:
Pressure: 20 to 50 psig (1.4 to 3.5 bar) Temperature: 70°F (21°C) maximum Consumption: 15 gpm (57 lpm), peak
• Steam:
Pressure: 50 to 80 psig (3.5 to 5.2 bar) Consumption:
36" Sterilizer: 190 lb/hr (86 kg/hr) 48" Sterilizer: 255 lb/hr (116 kg/hr) 60" Sterilizer: 335 lb/hr (152 kg/hr)
2-3
Installation Verification
Operator Manual
129373-461 2.2.4 Environmental Conditions
Temperature: 50° to 90°F (10° to 32°C) Humidity: 10% to 90% noncondensing Pollution Degree: 2 Installation Category (Overvoltage Category): II A-Weighted Sound Power Level: = 85 dBA (maximum)
trying to follow your original post writing, what specifically is JACHO asking?
typically humidity questions are related to the room, from JACHO's website
https://www.jointcommission.org/standards/standard-faqs/ambulatory/environment-of-care-ec/000001275/
