Fri Nov 08 2024
Plumb errors
I am getting an error N183 and N 185 proximal occlusion. When I try to back prime I get error E433 malfunction
   RE: Infusion Pump Report Post
Sun Nov 10 2024Reply from MapleTreeBiomed
MapleTreeBiomed
Hi JaciD,
E433 means the proximal pressure sensor has failed.The service manual says to replace the Mechanism Assembly. You can find the service manual in the documents section on the left. The sensor failing would easily cause your other errors.
Good Luck!
Thu Dec 12 2024Reply from juanscott
I have the same problem but such a pity I saw this thread too late. As you said, mine caused other errors and I had to quit it
getaway shootout
