Tue Nov 12 2024
Rapidly tube hot message then swithing the system
Rapidly tube hot message then swithing the system?
Equipment: Siemens - Axiom Artis
   RE: Cath/Angio Report Post
Tue Nov 12 2024Reply from JulioLeduan
Hello, check tube watter cooling system, you can contact me leduancuba@gmail.com
and check also tube thermal switch
Wed Nov 13 2024Reply from Emily Vitkovitsky
Emily Vitkovitsky
