Wed Jan 01 2025
Service Indicator Light
How to reset service indicator light?
   RE: Bed Report Post
Thu Jan 02 2025Reply from Jlinton
Jlinton
1. Perform a Soft Reset (Basic Step):
  • Turn Off the Bed:
    • Disconnect the bed from the power supply by unplugging it.
  • Wait:
    • Leave it powered down for about 1–2 minutes.
  • Turn It Back On:
    • Reconnect the power supply and turn the bed back on to see if the service light clears.
2. Reset Through the User Interface:
If the bed has an advanced control interface or diagnostic menu, you can reset the service light manually:
  1. Access the Menu:
    • Navigate to the settings or diagnostic menu on the control panel.
  2. Locate the Reset Option:
    • Look for options such as "Service Light Reset" or "Maintenance Reset."
  3. Follow On-Screen Instructions:
    • If prompted, confirm the reset.
    • The service light should turn off.
3. Perform a Manual Reset via Service Mode:
For certain models of Hillrom beds, you may need to enter service mode to reset the light:
  1. Enter Service Mode:
    • Refer to the service manual for specific steps. This often involves pressing a combination of buttons on the control panel (e.g., holding the "Up" and "Down" buttons for a few seconds).
  2. Reset the Indicator:
    • Once in service mode, select the option to reset the service indicator.
  3. Exit Service Mode:
    • Save changes and exit service mode.
