Anyone know where i can find the fluorescent backlight tubes for the preview screen on a Pagewriter xli M1700A? The service manual does not list the part number.
Fri Apr 01 2011
need backlight pagewriter xli
Sat Apr 02 2011Reply from GaryBiomed
You probably need to find out the OEM P/N for the LCD display. This is the back light from inside of a LCD display right?
Probably made by NEC
Mon Apr 04 2011Reply from DAD591
Thanks for the idea. It's a Toshiba TLX-1501-C3M1. Searching that I found displays but no backlights.
Mon Apr 04 2011Reply from GaryBiomed
At least getting the whole display should be alot cheaper then getting a new display from Philips.
They would probably charge you an arm and leg.
Good Luck
Just Googled LCD Display Bulbs
[url=http://www.bulbdirect.com/]http://www.bulbdirect.com/[/url]
Says they have them
or
[url=https://www.interlight.biz/]https://www.interlight.biz/[/url]
Mon Apr 11 2011Reply from Freelance
Okay, here is a "bush solution" you might want to check with a computer repair shop. They might be able to match up the tube with a tube from a laptop display that has gone bad. May not be perfect, but when in a pinch. .. ..
