IE33 Ultrasound unit (E cart)
Robert Hijazi
[url=http://www.usbiomedicalservices.com/Home.html]U.S. Biomedical Services[/url]
Is the speed specific to only your unit or does it seem to be universal? I agree that it may be beneficial to check the fan. After that you should check the archived data. Sometimes the system just needs to be cleaned out. If you have years and years of patient information you may want to export it and make some room for new information. I did some research and if the issue is technical, I found that you can purchase new equipment or a new ie33 online. Try those options first, however. Let me know if they work.
1. Check to see if you are sending the images as compressed vs. uncompressed by getting into setups. Difference being sending a zipped MB file and an unzipped megabyte file. That is the most common cause of slow send issues.
2. Clean out your patient database file. If operators are simply deleting it leaves behind widows and orphans. Although formatting should have taken care of it. Simply go to setups, print/network and global config. find the reset patient database button and proceed.
3. I have seen three machines with intermittent issues along these lines that had bad incoming power cables. These systems are very susceptible to poor ground issues and the power cords that Philips supplies are cheap and the it seems the grounding is the first thing to go.
Let us know but I would almost bet my teenager that you are sending in uncompressed mode.
do you use MWL? worklist? is that also slow? delete ALL patient files, use the network settings from 2nd system to isolate issue with system or network info. If still happens on this system check ALL network settings, compression settings, and such in set up screen.
