Thu Jan 09 2025
Unable to shut down properly.
After pressing the power button, the screen turns off after a few seconds, but the keyboard and button lights remain on. It seems like the shutdown process isn't completed. During this state, pressing the power button again doesn't turn it on, and the only way is to forcibly unplug the power cord to cut off the power.
Has anyone encountered this kind of situation?
Mon Jan 13 2025Reply from Emily Vitkovitsky
Emily Vitkovitsky
MERCO Biomedical
Wed Jan 15 2025Reply from SHENYEH
thank you Emily,
I had wrote to MERCO.
thank you for your assistance. I will wait and see the result.
Mon Jan 20 2025Reply from T.COX
What's up the make and model of the ultrasound?
Wed Jan 22 2025Reply from SHENYEH
SONOSITE M-TURBO , can't shut down after press power.
you can hear beep sound amd monitor shut down , but the light of keyboard is on.
Wed Jan 22 2025Reply from DELACHAGAS
DELACHAGAS
olá  amigo  você ja  teste o  equipamento direto  sem a  bateria ?
hello friend have you tested the equipment directly without the battery?
Mon Jan 27 2025Reply from SHENYEH
DELACHAGAS,
"The condition is the same if use battery
Wed Feb 05 2025Reply from BMETDoug
I am also having the same exact problem. If the battery is charged, I have to remove it and unplug the power to get the unit to turn off. Tried operating without a battery and with different known good batteries. Same results in all cases.
Fri Feb 07 2025Reply from SHENYEH
BMETDoug ,
Have you still not found a solution? How long has this been going on?
To forced shutdowns , I'm worried that the software on the SD card might get corrupted. If that happens, maybe I may need to reinstall the software.
