Fri Jan 10 2025
Program new transducer probes 5C2 and 6L3 to be used on the Sequoia C512.
How do I program new transducer probes 5C2 and 6L3 to be used on the Sequoia C512.
Equipment: Acuson sequoia C512 Ultrtasound
Fri Jan 17 2025Reply from Jlinton
Jlinton
To program and use new transducer probes, such as the 5C2 and 6L3, with the Acuson Sequoia C512 Ultrasound system, follow these general steps. The Sequoia system is designed to automatically recognize compatible probes when connected, but you may need to configure or enable them in the system settings if the machine does not recognize them immediately.
Steps to Program Transducer Probes:
  1. Connect the Transducer to the System:
    • Plug the 5C2 or 6L3 transducer probe into the appropriate port on the Sequoia C512 console.
  2. Power On the System:
    • Turn on the Sequoia C512 and wait for the system to load.
  3. Access the "Transducer" or "Probe" Settings:
    • On the main screen, navigate to the Transducer Settings or Probe Settings section (this can typically be found under the "System Settings" or "Configuration" menu).
  4. Enable or Program the New Probe:
    • The Sequoia should recognize the connected probe automatically. If not, there should be an option to manually add or program the probe.
    • Select the appropriate probe type (e.g., 5C2, 6L3) from the available options or use the “Add Probe” function if needed.
  5. Confirm Calibration or Settings:
    • Once the probe is recognized, you may need to confirm its settings or calibration.
    • Some systems may prompt you to verify or adjust the frequency, depth, or other specific settings related to the probe's characteristics.
  6. Save and Exit:
    • After configuring the probe, save your settings and exit the menu.
    • The system should now be ready to use the new transducer probe.
Troubleshooting:
  • If the probe is not recognized: Ensure that the probe is properly connected, and the cable is undamaged. Try restarting the system after reconnecting the probe.
  • Software updates: In some cases, a software update may be required for the system to recognize new transducers
