Hello every body I m facing issue in mamo .I turn on the machine it's work properly after some time may be within 10 min error shown like Gentry reset I press the ok button then it's working but after few min again error shown Gentry reset and Gentry switched off there is no error in led board please assist me .
Philips mammo diagnost dr
The "Gantry Reset" and "Gantry Switched Off" errors on a Philips Mammo Diagnost DR system indicate that the gantry is either losing power, experiencing a communication failure, or detecting a safety fault. Since the error occurs repeatedly after a short time, possible causes include power supply issues, interlock failures, overheating, or faulty connections.
Troubleshooting Steps:
1. Check the Power Supply
- Ensure the system is connected to a stable power source.
- Verify the input voltage is within the required range (refer to the service manual).
- Check the circuit breakers and power cables for any loose or damaged connections.
- If the facility has power fluctuations, consider using a UPS (Uninterruptible Power Supply).
2. Inspect Cooling & Ventilation
- Overheating can cause the system to shut down. Ensure the ventilation fans are working.
- Check for dust accumulation in cooling vents and clean them if necessary.
3. Check Gantry Safety Interlocks & Emergency Stop Buttons
- Some interlocks may be triggering an automatic shutdown.
- Inspect emergency stop buttons on the gantry and console to ensure they are not partially engaged.
- Verify that the gantry motion sensors and position sensors are functioning properly.
4. Inspect Communication Cables & Connections
- Loose or failing gantry communication cables can trigger this error.
- Check for any damaged or disconnected cables inside the gantry and between the gantry and workstation.
- Reseating (disconnecting and reconnecting) the gantry control board connections may help.
5. Check for Software or Firmware Issues
- A software issue could be causing repeated gantry resets.
- If the system logs errors, check the error codes in the service menu.
- Try power cycling the system by turning it off for 10–15 minutes, then restarting.
6. Inspect the Gantry Motor & Drive System
- If the gantry motor is failing or overheating, the system may reset it as a protective measure.
- Listen for unusual clicking, buzzing, or overheating noises from the motor.
- If possible, check for error logs related to motor function.
Thanks for your time.
All the connections are ok and also room temperature is around 18 degree but I doubt there is 24 volt power supply involving coz there is no error in the control board leds. When gantry turn down just one supply not behaving good.when machine turn on ready position supply showes 2 led but when gantry is off supply showes 1 led.
