Mon Apr 14 2025
Err 144/32
Err 144/32
Equipment: Agile Max
   RE: DR Systems Report Post
a day agoReply from Jlinton
Jlinton
Error 144/32 on an Agile Max system (likely from Ziehm Imaging or similar mobile C-arm X-ray equipment) typically relates to a communication or positioning issue with the system’s components, especially the generator or positioning sensors.
Likely Causes:
  • Faulty or misaligned position sensors (e.g., angle sensors, encoder)
  • Loose cable connection or a broken wire in the arm movement subsystem
  • Internal communication issue between the main controller and motor driver
  • Failed or misconfigured software/firmware initialization
