Please help me decipher the errors 12-34-1-0
appear when working on a large focus
Equipment: Siemens mammomat fusion
The error code 12-34-1-0 on the Siemens Mammomat Fusion typically refers to an issue related to the X-ray tube control or high-voltage generator, specifically when using the large focus setting.
Let’s break down the code:
So for:
12 – Likely refers to X-ray generator / HV issues
34 – Possibly points to focal spot control or tube filament current regulation
1 – May refer to focus selection or exposure triggering issue
0 – Indicates first occurrence or default detail code
The system is encountering a problem switching to or operating with the large focal spot. This could be due to:
A faulty filament or focus selector relay in the X-ray tube housing
An issue with filament current regulation (too low or too high)
A communication issue between the tube head and generator
A failing high voltage generator component that struggles with high load
Power Cycle System
Fully shut down and restart the Mammomat.
Clear the error and retry with small focus to isolate the issue.
Inspect Filament Voltages (if service mode accessible)
Check if filament current/voltage for large focus is within normal limits.
Try Low mAs Exposure on Large Focus
If it works at low power but fails at higher, it's likely a tube or HV generator degradation issue.
Check for Recent Maintenance
Has the tube been replaced recently?
Was the generator calibrated properly post-install?
Check Cables and Connectors
Inspect HV cables to the tube for signs of arcing or wear.
Reseat all connectors from the generator to the tube assembly.
Greetings to all.
I have already encountered this defect and 95% of the time it was always the defective tube. I am not saying that these defect codes are the same, but I ask that you focus on the tube.
