you man not get high-sensitive OCT image(2013)
Equipment: Topcon OCT-2000
En este equipo la resolución más alta es cuando haces el escaneo de línea. Y el de líneas de rastreo. Solo en esos 2 scans
Hi Khantek,
If you are still experiencing the “You may not get high-sensitive OCT image (2013)” error on your OCT-2000, I may be able to help.
This error can be related to the SLD output power and optical alignment. In some cases, cleaning the galvanometer mirrors and the optical path can improve the signal. If the problem remains, Y-position and other optical alignment adjustments may be required according to the service procedure.
If you are still working on this unit, let me know. I can help you troubleshoot it step by step.
