My ultrasound channel is showing up as unavailable. I wanted to try and buy a new wand to determine if it is the wand or the unit. But I can't find one anywhere. Looks like the part number is 77501A
Ultrasound issue
Ok these are no longer available new. Chattanooga stopped producing these many years ago. Having them repaired or rebuilt is the only option
Hey Doc Nev,
Usually that message means the cable is broken. Happens all the time. Replacing the cable requires some soldering that can be a bit of a pain. You almost need a butane torch to get the ground off.
Anyway, I usually buy parts from https://mrchatt.com/ for that generation. He doesn't have it on the website but Ken has 5cm wands on hand. Not associated with the site, just a customer.
Good Luck!
Hi Doc Nev, it seems like your issue may stem from a broken cable or a faulty ultrasound head. If you're unable to source a new wand, consider having it repaired or rebuilted.
