Wed Jun 11 2025
Error code 68 and serial communication lost
Has anyone experienced error code 68 and serial communication lost? If so what was the fix.
Thanks.
Mon Jun 16 2025Reply from Jlinton
Jlinton
That code usually means the system isn’t talking properly to one of its parts — like the gantry or control box. It’s a communication issue.
Try this:
Shut everything down — system and PC. Wait a full minute. Then power it all back up.
Check the cables — especially the serial or USB-to-serial cables between the computer and the rest of the system. Unplug and plug them back in.
If there’s a USB adapter, swap it with a known good one — those go bad all the time.
If this doesn’t work go into Device Manager on the PC and check if any COM ports have a warning sign or if anything looks weird.
If it used to work and now suddenly doesn’t, it’s almost always a bad cable, a loose connection, or a USB adapter acting up.
