How to rectify voltage error code
Equipment: Baxter - AK 98
Let me know what the error code number is if you have it — that'll help narrow it down even more. Otherwise...
Start with the basics:
Power Source – Make sure the machine is plugged into a stable outlet. Use a voltage tester if you can. Low or fluctuating voltage will trigger errors.
UPS or Surge Protector? – If it's plugged into a UPS or surge bar, try going direct to the wall.
Power Cord – Look for any kinks, damage, or loose connections.
