There’s a piercing noise coming out from my hospital bed but it’s working properly when I plug it back on. What might be causing this noise?
Equipment: Hillrom - Advanta
Hi Harriett Reichard,
Is the piercing noise all the time? When you move a section, if so which section. Is ti only up or down or both?
That noise could be an alarm from the bed’s control system, often caused by a loose connection, stuck button, or motor strain. If unplugging and plugging back in stops it, it might be resetting the fault. Check cables, connections, and if a specific movement triggers it. If it continues, refer to the manual’s alarm codes or have maintenance inspect it.
