Fri Oct 24 2025
ERROR E-4
Hi, can somebody help with E-4 error code that I get when trying to start. I can't find any documentation with this error. If somebody has the service manual, please share.
Equipment: UNICO - PowerSpin DX
   RE: Centrifuge Report Post
Mon Nov 03 2025Reply from Emily Vitkovitsky
Emily Vitkovitsky
Ozark Biomedical
United Infusion
Mon Nov 03 2025Reply from Jlinton
Jlinton
E-4 on a PowerSpin DX usually means the controller isn’t getting a valid lid/door or rotor home signal at startup — the machine refuses to run for safety. Could be a simple switch/wiring issue or a failing position sensor/drive board.
Quick checks (do these first):
  1. Power-cycle completely (main off ? wait 30s ? on).
  2. Open/close lid several times and watch/feel the lid-lock engage.
  3. Inspect lid interlock microswitch and wiring for loose plugs, corrosion, broken pins.
  4. Manually check rotor can move freely (power off) — no jams or debris.
  5. Check main fuses and the motor/drive supply voltages if you can safely access them.
  6. If there’s a service/homing routine in the menu, run it and note where it stops.
Mon Nov 03 2025Reply from MetroMag
Thank you for your response. I will do the checks you recommended first. Also, I will check the start circuit of the motor, because the centrifuge doesn't show the error if you give a little assistance to the rotor to start.
