E020 reference adjustment error
How to slove it .
What usually fixes it:
Clean the flow cell and optical window — dried hemoglobin residue is the #1 cause.
Prime/flush the reagent lines — any tiny air bubbles during the reference read will trigger E020.
Check the lamp output — weak/degrading lamp causes unstable reference levels.
Verify the reference cuvette path is seated and not contaminated.
Re-seat the detector board connectors — intermittent optics power can throw this exact error.
If it keeps coming back then the optical assembly is drifting and needs replacement or factory alignment.
