Sun Nov 23 2025
Key pad
Need information or video on how to replace the keypad on the X-12R
   RE: Centrifuge Report Post
Tue Dec 02 2025Reply from MapleTreeBiomed
MapleTreeBiomed
Hey Dpilot001,
The control panel is a stick on membrane that is part number 392377. I'm seeing them for sale here and there online.
Unplug the unit. I believe there are a few screws keeping the housing the control panel on. There will be a flat ribbon cable from the membrane/control panel the comes through and loops down onto the control board. Removed that then scrape off the membrane. The replacement goes on like a big sticker with the ribbon cable fished through the hole and plug it onto that board. Assemble the front back together and you should be good to go.
Good Luck!
