Mon Nov 24 2025
Recorder Common Error
Recorder Comm Error how to repair? Replaced printer same issue
Equipment: Mindray cPM8 Monitor
Mon Dec 01 2025Reply from Jlinton
Jlinton
The cPM8 “Recorder Comm Error” is usually:
Bad printer communication cable or loose header on the mainboard
Blown recorder interface IC on the mainboard
Wrong/unsupported printer module
Quick hits:
Reseat the recorder ribbon/cable both ends.
Check for bent pins at the printer connector.
Swap in a known-good recorder cable (most common fix).
If still dead — mainboard recorder interface is fried.
Printer replacement alone won’t clear it.
