When I turn on my E10 i reaches the GE startup screen with the progressbar. Then it stops - a messagebox apperas with an error and it turns off. I never hear the relays clicking.
If I turn the machine off at the outlet and wait until it compleatly turns off and then turn it on it starts normally. I do get an battery deteroiated error when booted. If I try to restart (without turning it off at the outlet) it won´t start op again?
Is this a common behaviour when the battery is dead?
Later:
I got a battery communication error - when I pressed the battery icon at the bottom. When I turned the machine off and tries to start it again it stops at the progressbar whatever I do and shows the error message and turns off.
Ok, the culprit was the batteries - the machine for some reason won´t start if there is a communictaion error with the batteries. Removed them and now it starts - every time.
Have ordered new ones.
