My sinothinker SK9000 keeps showing this error HGB Lamp failure and the result is inconsistent
What should I do please
Equipment: Sinothinker SK9000
Replace the HGB lamp module – this fixes it 90% of the time. They’re consumables and don’t last long.
Check the lamp connector – make sure it’s fully seated; loose connection = flicker = inconsistent results.
Clean the optical path – dust or cuvette residue can also mimic a weak lamp.
Run a full optical calibration after replacing the lamp.
If the error stays after a new lamp and calibration, the HGB photodiode board is your next suspect, but that’s far less common.
